Sean-newbie
Flight distance : 15997 ft
If I remember correctly on the GL300A's and posssibly the B's isn't there a chip on the USB board that can go wonky if its not used for some time?
I can't remember if the USB boards are interchangable across the GL300 A, B & C range, perhaps someone could comment on that.
Djiguy001 with regards to replacing things, don't go overboard when tighten ANY of the screws. The 3 screws that secure the USB board can split the standoffs into which they screw and the Allen screws can pull the bottom of their holes in the cover off the cover. I barely nip them up.
If you get the HDMI module make sure the metal surrounds of the various ports are actually lined up with the holes in the outer shell, some of them seem to be slightly off, enough that the shell needs manipulating to get surrounds into the openings. |
