Mari
Flight distance : 1308780 ft
When you start DJI Assistant 2 (version 1.1.6) and select your MP, you will get an error message about the SD-Card in the MP, ignore this message...
You can find your flight data under "data upload". Only flight data since your update to FW .1000 can be found there. You can select them and safe them local.
When you then go to "flight data" you will get the same error message about the SD-Card, ignore it again... open "Data viewer" and open one of the saved DAT-files... Don't know how "Data viewer" works, so I don't get any data on the screen. But when I open the same saved DAT-file wit CSVview I can view my flight data. |
