lannes
Flight distance : 4465 ft
First thing, I would reinstall the firmware even if you have just upgraded it
In the setup process make sure you have fully charged batteries in the AC and RC
You don't normally use the app to connect the AC and R/C, that is backwards using the app first.The manual doesn't even mention using the app
I think you are out of sequence with the linking,
1) we see in your video at 2.10 you put the AC into linking mode (3 sec battery press and red flashing confirmation) but you never put RC into linking mode (RC Pause, function and Custom button, press and hold)
2) at 10.38, you put the RC into in linking mode, but the AC is not in linking mode (no 3 second press of battery, no red led flashing)
In both cases on one is in linkining mode and the other is not, both need to be in linking mode at the same time
follow the instructions closely
Also don't connect the phone to the R/C wireless , just do the re linking process only with the RC and AC follow the process above.
In any linking process, start the AC first
The DJI Go4 app is always the last thing you connect to the RC, you first turn on the AC, then the RC wait for the solid green connection before you connect the phone to the RC via wireless and then launch the app
