Flying in Parad
Flight distance : 180958 ft
New Zealand
Hi Everyone. 2 minutes into a flight yesterday the aircraft was hovering and stationary about 5 mtrs off the ground when the rear left motor seized and needless to say the aircraft took a rapid uncontrolled path towards the ground. Before I could get to the aircraft (only 5-6 mtrs away) there was smoke coming out of the motor and it was far too hot to touch. Switched everything off and took it back to base to cool down.
Once the motor had cooled down I set up another flight to test the situation and as soon as I started the motors the prop on that motor again seized, I tried this twice with the same results. Anyone else had experience like this?
Cheers. Laurence.
