Dobmatt
Flight distance : 1831050 ft
Dingoz Posted at 2017-9-14 17:17
Or better phrased perhaps is a 'low voltage cut off' is commonly used to refer to 12v DC products that cut-off leaving a safe enough charge in the car battery to start the car such as 12.3v. If the device cuts off at 13v then its not really a low voltage cutoff feature in the more common sense of the term... it more accurately is a full battery cut ensuring the car battery is not depleted at all when the engine is off (in other words leaving a car battery at 100% full state of charge vs 50% low state of charge but safe to start still).
Anyway I just would like to know before I buy the expensive OEM charger can it operate and cut-in / start charging at 12.3v or is it 13v (2 different specs listed for this device so which one is correct)?
Since most of my aerial photography is made in remote wilderness and off the boat, the battery charging issue is of paramount importance. I spent countless hours researching and experimenting with various solutions, ending with DIY devices based on commonly available step-up voltage converters. These work with voltages as low as 10V. I can't tell you what is the actual minimum input voltage for DJI car charger to kick in, didn't bother to measure. But for sure you need to keep car battery in good shape. Avoid charging with engine shut off, even idling motor may not provide enough energy from alternator. Bottom line: only charging during driving is reliable enough and will not leave you with dead car next morning. Been there, did that ...
Neither DJI or any 3rd party Chinese clones couldn't provide enough juice to charge multiple batteries at once and reasonably fast for my needs. If that's not your case, than DJI charger in question will do just fine during drive from one place to another. Here's my 2-channel charger: see the charging current! Two Inspire batteries need up to 25A current ... Takes about 65 min to fully charge 2 batts, with input directly from car battery posts. No cigarette lighter socket will tolerate such abuse, believe me ...
However, if you're in desperate need for field charging energy, than venerable Honda generator and multiple chargers is your best bet.
