fans61699a75
Flight distance : 24971795 ft
Otg is the cable connected between remote controller and device iphone , ipad for example. Before the dji go 4.1.10 update it worked pretty well, also good image transfer, although dji claimed not to use it as it was not tested. Now with the 4.1.10 it makes no difference if you using wifi or wifi together with otg cable. Therefore you might aswell not use it( maybe again with a new firmware update)
If you using the otg cable without wifi it resets distance to 100 meters and height to 50 meters. Rth height only 50 meters. So for the time being you can skipp the cable |
