Cetacean
Flight distance : 2285023 ft
JockC Posted at 2017-9-22 19:08
After more than 35 years marketing and supporting firmware in various devices, your description of what can go wrong with firmware has added nothing to my understanding of the current firmware issues. Whether the firmware itself is faulty or whether DJI's installation process is at fault is irrelevant. It is all part of the firmware release and DJI clearly got it wrong for many users.
What is possibly worse than the faults, though, is DJI's handling of the issues. Specifically, they have not categorically acknowledged the shaking problem nor have they stated what reloading the firmware with the new Assistant 2 is meant to fix. Instead, they give a loose acknowledgement of some firmware issues and then advise people to reinstall the firmware using the new Assistant2 but give no explanation as to what it may or may not fix.
Aloha Jock,
Somehow, you are not communicating to me. Sure thirty five years marketing and supporting firmware shows some experience, but to me, that experience should impress upon you the risks and downsides of cutting edge technology. Have you ever even worked with cutting edge firmware in your thirty five years?
Another point that seems to completely fly over your head, is that the US and Australia are markets for a company based in China. Now, it is a Chinese Company that is developing and marketing cutting edge technology. China has a completely different way of doing business and this difference even goes so far as looking at the world itself. What is important to Australians and the US is not as important to the Chinese. So, there are cultural differences that come into play. For some reason, you seem to want to hold the Chinese Company to a US and Australian standard they have no interest in. Do you want their product or not? It is OK for DJI to be very "bottom line". They hold the standard. Kind of like the Apple of Asia. I am not very fond of Apple and their products at all.
Basically, it seems to me that if you are not happy with your DJI product, you should vote with your pocketbook and buy another product that will match your expectations. Clearly the Chinese product does not.
However, having said that, it is good that you keep monitoring the possibilities for a breakthrough for your P4. Personally, I think you should try what DJI recommends, after all they developed the technology. Maybe you will find some solution or just roll back your system. It is totally up to you.
Like some have said on the Forum, every update is like Christmas morning - new presents. If you are satisfied with last years P4, roll back the firmware and fly last years firmware. There will be no Tripod, etc., but you will have last years product flying the way you want it to fly.
As for me, I was able to get my P4 up and out to test the high speed wobble that is the closest I get to the problems seen by others. It turns out that vertical and horizontal max speed efforts are straight with no wobbles. But a max speed descent or rise at 30-60 degrees does indeed produce a wobble. It looks to me that I should be able to remove the wobble with setting changes, but it is indeed there.
Tomorrow and Sunday, I will try the refreshed and new firmware installed with the new DJI Assistant 2. At least I have a test to see if there is a difference.
Mahalo for the conversation.
Aloha and Drone On! |
