Jenee 2
Flight distance : 7852129 ft
Well the first thing you need to do is update the firmware in both the Mavic and RC preferably to the latest and definitely so they are both the same. You really should not fly with different firmware in those two. Also update your DJI GO 4 app.
Normally, if the app disconnects, there is no need to panic, just use the remote to fly the drone home.
Are you certain that the RC was not working?
In a case where the RC is not working then it is possible to turn it off and restart it but that will trigger the drone to return home. If you reestablish the connection then you can continue flying but I would be seriously looking at why the RC disconnected. It is not unusual for the app to disconnect. |
