Bob Brown
Flight distance : 4209662 ft
HyLenz Posted at 2017-9-28 15:46
I have had the same issue, first noticed back in June. Mavic was perfect until i started seeing the CPU overload message, choppy live feed and iPad getting hot. DJI is aware and says there will be a fix with the next set of updates, per Thor. But i wouldn't say this is entirely DJI's fault. I did some testing today. iPad Mini2 32GB, ios 11, all latest DJI Go 4 and firmware. Earlier this week, i got the CPU message at about 25 minutes total, 20 minutes on the first battery, then land change battery, and maybe 5 minutes into the second. This ended my day. I had driven about 4 hours just to film at this spot. This has happened several time this summer.
Today, i reset my iPad back to IOS 10.3.3 and reloaded DJI Go 4. I flew through all 3 batteries, about 55 minutes without a problem. The iPad did not get hot, not even a little. I would guess Apple made some changes along the way that affected DJI's code. I am confident DJI will catch up. In the meantime, if you have a iPad dedicated for flying, try downgrade to IOS 10.3.3 until it gets fixed. It worked for me, but do it at your own risk. IOS 10.3.3 is still signed and available here: https://ipsw.me/. Use itunes to restore.
This worked for me also! I am not updating GO or iOS for a while now that it is working.
I also did refresh the latest FW on both RC and AC but I have heard this is not necessary.
For now I will pass on any updates until Apple and DJI start holding hands and are getting along a bit better. |
