Spark repaired under warranty - weak GPS errors & drifting persist
12Next >
6660 63 2017-9-28
jcwconsulting
Flight distance : 944236 ft
my original thread is located here. DJI diagnosed the issue as a bad GPS receiver, & it was replaced under warranty. however when i tested the newly repaired AC @ my local field, there were multiple weak GPS signal errors & even an ATTI mode incident forcing me to fly it back manually. thus, my Spark seems to be exhibiting the exact same symptoms as before (minus compass & IMU errors). i also experienced noticeable diagonal drift which was solved by performing an IMU calibration. unfortunately, the AC still wanders during hover.
right now, i'm about ready to enter a vote of no confidence on DJI altogether.
Diana - can you help? am pretty much at the end of my rope here...
2017-9-28
DJI Elektra
Jcwconsulting, sorry for the unpleasant experience. Please tell me your previous case number so I can check more details for you. Thanks for your support.
2017-9-28
jcwconsulting
DJI Elektra Posted at 2017-9-28 20:14
Elektra, thx for your reply - here's my original case #: CAS-980962-C8K4G2
if you can see what my options are, i'd greatly appreciate it. at this stage, i'm kind of ready to return it for a brand new warranty replacement.
thx much
2017-9-28
DJI Elektra
jcwconsulting Posted at 2017-9-28 20:28
if you can see what my options are, i'd greatly appreciate it. at this stage, i'm kind of ready to return it altogether for a refund.
Can you provide a screenshot with the error message? Please shoot a video when your AC wander during hover. Thanks for your update.
2017-9-28
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
If outside, AC wander during hover in "ATTI" mode is normal.
2017-9-28
jcwconsulting
DJI Elektra Posted at 2017-9-28 22:15
yes, will do - flying it again later today & should be able to recreate that error pretty easily. i've already captured some footage of the hover drift. will post both in a few hrs...
thx
2017-9-29
jcwconsulting
Ahmed Hussain Posted at 2017-9-28 22:57
this was not in ATTI mode - it happened w/GPS lock of about 10 satellites
2017-9-29
Wachtberger
Flight distance : 261509 ft
jcwconsulting Posted at 2017-9-29 07:54
thx
That will be interesting to see, thank you for your efforts!
2017-9-29
jcwconsulting
Wachtberger Posted at 2017-9-29 08:24
no worries - it's all in my best interest, anyway...
2017-9-29
jcwconsulting
okay, so i flew 3x today - during the first flight, my Spark threw an ATTI mode error & had to be landed manually (nothing new lately). during the second flight it held GPS lock throughout, for some unknown reason. during the third flight i experienced multiple weak GPS signal errors & hover drift. plus on 2 of the 3 flights, its GPS lock consistently fluctuated between 7-14 satellites (wildly jumping up & down) as i flew it around the venue. below are 3 of the 5 various error screenshots f/today plus a video f/yesterday while it was hovering.
FYI, that NFZ warning in the last screenshot is completely inaccurate since the nearest airport is like 16 miles away.
now, i'm pretty sure something is still bloody wrong w/this unit - what we can we do about it here??
video:
screenshots:
2017-9-29
DJI Susan
jcwconsulting Posted at 2017-9-29 17:05
Just to verify, does the drone drift every time even there is enough GPS signal? According to the screenshots you offered, it seems that the GPS signal quality is not very good(only 2 bars, instead of full).
Also, please kindly offer your DJI account and sync the flight records, we will look into it.
2017-9-29
jcwconsulting
DJI Susan Posted at 2017-9-29 22:58
the AC drifts almost every time i hover, no matter what the quality of GPS lock is. this poor signal has resulted in the 'weak GPS signal' error & a shift into OPTI mode (plus ATTI mode twice) over the last six flights. i almost always end up in OPTI mode, even if the GPS lock was excellent at takeoff.
flight records:
https://app.airdata.com/main?fli ... ENERALNotifications
flight data: https://www.dropbox.com/sh/iso21 ... 92vvlZ1xOpZkGa?dl=0
blackbox data: https://www.dropbox.com/sh/xsonj ... I62AznTRHGNfwa?dl=0
i'm will likely return the unit Monday - it's clearly defective, & i'm done wasting time w/these recurring issues after the fact.
2017-9-30
Jose Ramos
Flight distance : 72825 ft
Portugal
jcwconsulting Posted at 2017-9-30 09:57
flight records:
Regarding your previous drone, did the problem happen right from the start, or only after the mandatory upgrade?
2017-9-30
jcwconsulting
it's actually the same drone, & all of these problems only began after the 0.0600 update. before that, it flew flawlessly on 0.0500.
2017-9-30
Jose Ramos
Portugal
jcwconsulting Posted at 2017-9-30 10:44
I'm starting to think more and more that this is a software problem!
2017-9-30
jcwconsulting
the only way to know for sure is by flying it w/0.0500 loaded, which we can't do b/c of the BS mandatory nature of the 0.0600 update
2017-9-30
jcwconsulting
that's it - flew yesterday & had multiple weak GPS errors plus ATTI mode. this thing is getting returned for repair or replacement tomorrow...
2017-10-1
jcwconsulting
attn DJI Moderators: my new case # is CAS-1058842-F6F9G2. can someone see about escalating it? i'm requesting a brand new warranty replacement unit. your assistance is greatly appreciated...
2017-10-1
hallmark007
Flight distance : 9827923 ft
You always need to measure your gps by the bar graph usually 2 bars would not be more than 8 sats.
2017-10-1
jcwconsulting
hallmark007 Posted at 2017-10-1 12:50
there always seems to be a disparity between the bar graph & satellite count numerical displays. correct me if i'm wrong, but doesn't the bar graph indicate quality of GPS lock rather than actual satellite count? just want to clarify that for my own knowledge. thx for your input...
2017-10-1
hallmark007
jcwconsulting Posted at 2017-10-1 13:29
there always seems to be a disparity between the bar graph & satellite count numerical display. correct me if i'm wrong, but doesn't the bar graph indicate the quality of GPS lock rather than the actual satellite count? just want to clarify that for my own knowledge. thx for your input...
Yes it does, so if you take it you need 6/7 sats to fly with gps if number reports 12 sats you could have 7 gps 5 glonass, so if you really want to be careful reading numbers of sats 12 or more is the number you should be looking for, 3 bars.
2017-10-1
jcwconsulting
hallmark007 Posted at 2017-10-1 13:33
good to know - i'll add this to my pre-flight checklist going forward
thx again for the tip
2017-10-1
jcwconsulting
perhaps a useful feature could be 2 separate satellite count displays next to eachother, one for GPS & one for GLONASS - does that make sense to help discern specific positioning lock quality? i'd imagine so...
2017-10-2
jcwconsulting
okay, my Spark is on its way to DJI's repair center in Cerritos, CA. once again, the case # is CAS-1058842-F6F9G2. thx in advance to any DJI Mod(s) who can help escalate this warranty claim in a timely manner!
2017-10-2
jcwconsulting
FYI to DJI Mods - my warranty return has arrived @ DJI's Cerritos, CA repair facility as of 10AM today...thx in advance for any case escalation help you can provide!
2017-10-9
DJI Diana
Flight distance : 2408 ft
jcwconsulting Posted at 2017-10-9 09:24
It may take several days to unpack it and update the case in DJI system, please wait patiently, we'll keep an eye on it as well, will escalate it after it shows Received in DJI System.
2017-10-10
jcwconsulting
DJI Diana Posted at 2017-10-10 00:02
understood - thx for the update & your continued help, Diana
2017-10-10
jcwconsulting
FYI - shows as received in DJI's system as of late this afternoon
2017-10-10
DJI Susan
jcwconsulting Posted at 2017-10-10 18:54
The local team will do damage assessment according to your description. We will be here to follow up the case status.
2017-10-10
jcwconsulting
DJI Susan Posted at 2017-10-10 23:17
not my first rodeo & fully understand the process - nonetheless, thx for your clarification
2017-10-11
DJI Diana
jcwconsulting Posted at 2017-10-11 07:04
already been here once before & fully understand the process - nonetheless, thx for your clarification
Update: the drone has been tested, you should have received the email. It will be shipped out soon, we'll send another email with the tracking number once it is shipped.
2017-10-11
olivierm
Flight distance : 4177 ft
does it mean DJI team will provide software update one day or another concerning this behave ? Hope yes, cause I suspect to have the same kind of "issue".
2017-10-11
DJI Susan
olivierm Posted at 2017-10-11 23:09
Sir, could you be more specific of your issue? And what troubleshooting have you tried? I'd like to help.
2017-10-12
jcwconsulting
DJI Diana Posted at 2017-10-11 22:28
thx Diana - got that email yesterday evening, your help is much appreciated...
2017-10-12
DJI Diana
jcwconsulting Posted at 2017-10-12 10:42
You are welcome, the drone has been shipped out, I think you could receive it soon, hope you can enjoy it, have a nice day!
2017-10-13
hallmark007
Sweden
Good luck with your new one. Good job.
2017-10-13
jcwconsulting
hallmark007 Posted at 2017-10-13 10:36
thx much - i appreciate your well-wishes & valuable advice, as well
2017-10-13
olivierm
DJI Susan Posted at 2017-10-12 03:13
Hello Susan,
as I understood, there is a issue with the soft and drone or app should be updated. did I understand well ? if yes, my question was if it is planned to have an update of code soon  in the apps, or drone piece of code ;) (but I may have done  a mistake in unstanding correctly )
Olivier
2017-10-16
DJI Susan
olivierm Posted at 2017-10-16 01:31
Hello Susan,
Olivier
Sorry for the confusion. I do not think that the issue was related with firmware or APP. If you have similar issue, I would recommend you to change another location with good GPS signal and try again. Please keep us posted of the test result.
2017-10-16
jcwconsulting
received replacement AC & R/C late PM yesterday. activated, updated R/C firmware & charged all device batteries last night. went out for a test run today - flew perfectly on three consecutive batteries w/16-17 solid sats & excellent signal quality. thx again to Diana & the other mods who helped throughout this process!
2017-10-19
12Next >
