flihi
As usual I had a good flight with my Phantom 3 Professional last week. Got a low battery warning so I put the aircraft to the ground, smooth landing. Changed the battery for a full one and switched on again. After warming up, DJI Go told me the system was 'Ready to go'. But when trying to start the motors I got a message (in yellow) about the IMU being initialized. First I thought I had to be a bit more patient, but the situation did not change.
I decided to do an IMU calibaration. This stopped at 36% with an 'Unknown error'. I powered off and on again and restarted the IMU calibration, and now it stopped at 2%. From that moment, the app status line says 'IMU calibration required' after powering up, and calibration attemps stop at 2% every time.
Giving the aircraft a few days of rest, and cooling it (to 12 degrees Celsius) did not bring any difference, neither did updating controller, aircraft, and battery firmware.
I don't think it has anything to do with a stuck sensor. X/Y values for gyroscope and acceleration show values from -0,01 to +0,01 in rest position, and they increase/decrease when I move the aircraft.
Being desperate, I gave it a chance and tried an IMU calibration while the aircraft was positioned upside down. And gues what: this results in a 100% complete calibration! Now I was able to start the motors, but I didn't risk to fly with an aircraft calibrated upside down:-)
So I again tried calibrating with the aircraft in normal position. This resulted in an unknown error again, the first one at 22% and after that it was 2% again. This situation is reproducable:
- upside down calibration always succeeds 100%.
- then first normal positioned calibation ends at some random percentage (often 22%).
- following normal positioned calibration attempts end at 2%.
I read about Phantom 4 IMU calibration errors due to fan vibrations but I don't know if this issue relates to the Pantom 3 too. I can imagine that these vibrations have less impact at the calibration process when the aircraft is upside down, in opposition to when it is standing on its soft rubber feet.
A last notice:
Looking at 'Aircraft status/Overall status' in the DJI Go app, I see a rectangle containing the text 'Latest firmware!' followed by 'Abnormal' in red. I don't know since when this is, and if it has any relation to the calibration problems.
Does anyone have an idea what's causing this problem?
