Flip_L
Flight distance : 330686 ft
I posted about this issue in an other thread, this might help you:
the problem Android users encounter when trying to use the 2.4 GHz band (RC -> Spark) is such: in order to use the 2.4GHz band without an OTG-cable, the RC -> phone connection has to switch to 5.8 GHz. However, a lot of android devices (not all of them) can't connect to this band (for whatever reasons). Using a device which is running iOS solves this, as they have no trouble using this band.
In order to use the 2.4GHz band, which in Europe drastically increases range and image transmission sability, your mobile device has to connect to the RC via 5.8GHz and the RC -> Spark connection switches to 2.4GHz.
Using a OTG-cable is the only way for some android users to change the RC -> Spark connection to 2.4GHz, as the RC -> mobile device connection is no loger using WiFi and thus the 2.4GHz band becomes available.
Hope that helps. |
