andy.murden
Hi I have a 3 week old Phantom V+ v3. First 3 flights were all good over a two week period. Crashed on 4th flight. Had done all the pre-flight checks (as you do being new, quite paranoid getting it right) , wifi extender, tx, then phantom. Let it settle for a while and then do compass calibration. Turn on app, check sats are good and radar is all as should be. Take off, fly for a good 6-7 mins, no more than 150ft altitude and less then 100ft distance at all times and no issues. Battery gets to around 40% so bring it closer and hover 10ft above the ground and 10ft away from me, at this point the sticks are all mid way no input on them.
Then all of a sudden it takes a rapid dive to the right flipping over. Hits the ground on its back, was able to then throttle back and shut it down. Two prop guards broke and one prop. Luckily gimbal was not damaged. I did get a 'battery communication error' message on the app but now put that down to the battery ejecting slightly on impact.
So have not flown it since. Have re-calibrated the IMU, tx etc. Had an error 27 on the app for a while, which seems to have now gone away after repeatedly calibrating the compass. So all seems ok and good to go again.
However I thought I would just test the motors before taking it for a flight. Firstly without the props and could certainly tell they were moving from idle to full throttle at certain points of the test. Decided to put the props on, to see if that made any difference, which it hasn't. When I throttle up and then down, the motors remain steady for for seconds and then rapidly speed up (i'm holding it down on a table 3ft off the ground outside). I have left it idle for a few minutes and motors constantly revs high, I have to constanly throttle down to reduce motor speed.
I am really reluctant to fly now, which is a shame as I had gone to great lengths training myself with a Syma X5C watching as many videos as humanly possible. Yes I am a newbie, so it could be me but I have checked, doubled checked and triple checked everything I do.
If anyone has any feedback would really appreciate it.
Cheers
