usb charging won't work
12Next >
7083 57 2017-10-14
eFPi
Flight distance : 232710 ft
Hi there,
it turns out that my Spark won't charge via USB. I have the combo pack and tried to charge there batteries on the dock (worked fine) and one via USB. Spark turns on its van, but it won't show a charging light (even after one hour). Same thing when I only use USB and no dock, or with other adapters. Anyone an idee what is wrong here??
Thanks, and keep on flyin'
2017-10-14
Bright Spark
Flight distance : 22129 ft
Mine never turns fan on when charging on aircraft. I take it you haven't powered up spark?
2017-10-14
eFPi
Exactly, I just plug in, I don't press any buttons and the fan starts... but as mentioned, no indicator lights show up.
2017-10-15
Bright Spark
Obviously you're using supplied charger? Most usb ports are not up to job.
If you press batt button once, does it show discharged? ie one or two leds.
2017-10-15
eFPi
Yes, it's all supplied gear (usb cable and power adapter). And yes, the batts are discharged and would be ready to be charged.
2017-10-15
DJI Elektra
EFPi, did you try to change a USB cable? Please change a charging port. Please notice that the charging time will be longer if you use the USB cable to charge your spark.
2017-10-15
eFPi
Tries out all alternatives. Aleays the same: van on, no lights even after one hour
2017-10-15
DJI Elektra
eFPi Posted at 2017-10-15 00:25
Can you shoot a video about this situation? Please try to connect your spark with DJI Assistant 2 and see if it can identify your drone. If it fails to connect with computer, there is something wrong with port of spark. Thanks for your support.
2017-10-15
eFPi
Wow, this last post is terrible!
Sorry, again: I tried out all alternatives, but it's always the same: fan on, no lights even after one hour.
I'm already anxious that I could do any harm to the Spark or the batts if I experience any longer.
2017-10-15
Bright Spark
Desperate now! Real outside shot, inspect contacts on spark undeside, where batt connects. See if any are compromised.
Points to spark other wise. Can you see spark 's
Sd card when connected to pc.?
2017-10-15
Bright Spark
Further to that, when system powered up, do you see all 3 cells healthy in on board  monitor.
2017-10-15
eFPi
I will try to make a video. I will post that later. Thanks!!
2017-10-15
DJI Elektra
eFPi Posted at 2017-10-15 00:31
EFPi, don't feel so worry. We will help you figure out the problem, please keep us updated.
2017-10-15
eFPi
Ok, Spark connects with Mac and Assistant without problems. Here the link to the video:
https://www.dropbox.com/s/o8uxf65ru1x3pmh/IMG_9914.mp4?dl=0
@DJIElektra - thanks!!
2017-10-15
Bright Spark
I don't know that charger. Mine came with a little white one.
2017-10-15
eFPi
It might be the European Version of the Combo.
2017-10-15
m1n1s
Flight distance : 319915 ft
yep the combo charger.
2017-10-18
m1n1s
im guessing you might have a phone charger around the house which uses the usb micro connector, try the spark with that , it may work but take a long time to charge - the spark charger will charge at 9V @ 2A.
maybe there is a fault with the usb ports on the combo charger?
you can buy a simple usb tester online :
http://www.ebay.co.uk/itm/Mini-L ... :g:ip8AAOSwrddY8SXR
2017-10-18
eFPi
m1n1s Posted at 2017-10-18 01:13
Thanks, but I already tried several possibilities and none worked out.
I also plugged other USB devices into the combo charger - all worked fine with it.
It is strange...
2017-10-18
m1n1s
eFPi Posted at 2017-10-18 08:19
It is strange...
Can you connect the DJI assistant to the USB port of the spark?
Maybe the USB port is broken?
2017-10-18
eFPi
m1n1s Posted at 2017-10-18 08:24
Yes, that works perfectly.
2017-10-18
Bright Spark
Did the other devices use the same cable?
2017-10-18
Bright Spark
Also, I think I mentioned, does on board  batt monitor show three health cells?
2017-10-18
eFPi
Bright Spark Posted at 2017-10-18 09:22
Yes, cells are fine with all batteries!
Cable is fine with others.
2017-10-18
Bright Spark
Well , it looks a bit like spark issue, maybe just the usb connector. For the fan to come on is wrong I think, and might suggest the spark is incorrectly registering  hot batteries, for it will wait for them to cool if necessary before charging.
A job for DJI perhaps.
2017-10-18
Rawsome
Flight distance : 230827 ft
Actually just encountered the same problem - fans come on when Sparky is charged via USB. I haven't done this in some time as i usually have enough batteries but yesterday i needed more juice and couldn't get any
2017-10-18
Rawsome
Tested at home and it's charging now via USB - fan still going though.
2017-10-18
m1n1s
seems something in the firmware of the spark then?
i checked mine from the usb cable , charging and no fan.
2017-10-18
eFPi
Rawsome Posted at 2017-10-18 18:09
So, did you change anything that it charges now?
2017-10-19
BobD
There are USB Ports and USB Ports: The USB 1.x and 2.0 specifications provide a 5 V supply on a single wire to power connected USB devices.
A unit load is defined as 100 mA in USB 2.0, and 150 mA in USB 3.0. A device may draw a maximum of 5 unit loads (500 mA) from a port in USB 2.0; 6 (900 mA) in USB 3.0.
So your USB Port may not provide enough current to charge a Spark battery.
2017-10-19
eFPi
BobD Posted at 2017-10-19 02:34
How can that be, as it is the power supply of the combo pack of DJI?
2017-10-19
DJI Elektra
It is strange...
EFPi, I think you use the wrong charger. Please use the usb connector and charge your spark.
2017-10-19
eFPi
DJI Elektra Posted at 2017-10-19 03:36
I use the charger that comes with the combo. How can it be wrong to use original DJI products with the spark? Don't get it. However, it won't work with any other charger (plug, power bank, ...).
2017-10-19
DJI-Jamie
Flight distance : 112405 ft
eFPi Posted at 2017-10-19 05:40
Could you please verify what firmware versions you're running on the Spark? For the sake of troubleshooting, could you try resetting the unit to factory defaults via the Assistant 2 if everything is up to date?
2017-10-19
eFPi
DJI-Jamie Posted at 2017-10-19 09:12
Newest firmware. Am now going to resetting...
2017-10-19
eFPi
Same issue after reset. Van turns on, bat won't charge.
2017-10-19
eFPi
Here is a screenshot of the firmware:
2017-10-19
eFPi
btw. datebase has been updated in the meanwhile
2017-10-19
eFPi
So I guess I have to live with it
2017-10-21
BobD
The DJI Charger delivers far more current than a standard USB port.  Mine says 5 Volts at 2 Amps.
2017-10-21
12Next >
