chiplifter
Flight distance : 745180 ft
djiuser_zlCOGa9 Posted at 2017-10-26 06:54
Ok, I have found a workaround for this problem. I just got a Spark last week and set it up, so I don't have any older version of the app or maps to work with. However, I found a way to get maps downloaded from the Herewego app to the DJI app.
First, download Herewego and download the maps you want. Second, I'm not sure if this step is necessary, but open up the DJI app and try to download maps, even though it will stall out.
Thanks a lot for this wonderful tip. This worked for me on Android.
the steps I took are as follows:
1) I deleted the the folder DJI/dji.go.v4/.djiHereMap/diskcache-v5/
2) In de Here! App I downloaded a single map.
3) I copied the folder Android/data/com.here.app.maps/files/.here-map/diskcache-v4 to DJI/dji.go.v4/.djiHereMap/
4) Rename diskcache-v4 to diskcache-v5
After I start up DJI GO 4 All countries are showing up and the downloaded map is marked as 'Downloaded'
After these steps I even can download additional maps through the DJI GO 4 map.
