endotherm
Flight distance : 503241 ft
Nigel_ Posted at 2017-10-20 04:27
"Any ascent, forward flight or turning perfectly matches the controls performed by the pilot"
At 16m 6.3s the yaw is at -135, the first time it goes beyond -156 is over 2 minutes later at 18m 26s,
None of this is "haywire". It is all in response to control inputs. Each move has a corresponding manual cause.
Let's examine this segment with four 360° "loops", occurring at approximately
- 16:11.5
- 16:22
- 16:31
- 16:33
The image also contains a "paper plane" icon showing the orientation of the aircraft, which doesn't change during this period. It will retain this heading unless a rudder rotation is recorded. Sideways and forward/back movement can be performed with the right stick while maintaining this orientation.
Here is the data for the first loop.
We can see the Yaw value does not change. We can see there is no movement of the left stick (the first two grey columns/pink headings on the right). The yaw direction will not change unless there is rotational input -- left stick moved laterally. The other two columns show a haphazard movement of the right stick, pulsing up and right and reflected in appropriate pitch and roll angles from the aircraft accelerometer.
Perfect data, exactly what we expect to see in a flight analysis, and the responses from the aircraft are exactly what we expect from the input instructions. This is what a system without faults looks like.
The second "loop" also shows right stick being pulsed forward and some right input, explaining the sudden direction change, while at the same time maintaining the orientation of the aircraft in its SW heading.
The third and fourth loops, relatively close together are shown here, initiated by two right rolls. The extent of the rolls are shown in the roll column, indicating the aircraft is tipping over around 20°-25°. We also see for the first time any rudder input, causing the yaw direction to change from -135° to around -143°. This small lateral pulse from the left stick completely explains the orientation change.
NONE OF THIS INDICATES IT HAS GONE HAYWIRE!
I've never been particularly worried by the various brief warnings of compass/GPS errors. They are trying to tell you there is a mismatch of data, that the numbers are not making sense and conflicting with data from other sensors. They are usually brief and clear themselves once the data starts making sense again, so it is not the sign of a catastrophic failure or error. More likely, it is probably beyond the error tolerance programmed in to the firmware and the value returned is slightly beyond what is expected. Unless the error remains on the screen or is repeated constantly in short order, they can generally be ignored. Many pilots here seem to give the warnings way more importance than they deserve. If you can give us a definitive list of what each error message means, what causes it and in what circumstances, and why it was triggered, I'm all ears! I don't think any of us can say with any certainty what causes an error to be flashed on the screen, there are way too many permutations to consider. Just because we see "compass error", it's not indicating the compass has suddenly caught fire, it is saying the data is not making sense. The compass heading, for example, is corroborated by data from the GPS system, and yaw/tilt/roll data from the accelerometer.
Consider this scenario where the aircraft is travelling north. We are all aware with the phenomenon of compass needles drifting and oscillating while moving. The compass suddenly says "we aren't heading north any more, we are heading 10°". The GPS sub-system says, "no, we are still incrementing at the expected positional value, the latitude/longitude values don't indicate a lateral deviation" and the accelerometer says, "we haven't deviated sideways, we are still proceeding forward normally". Two out of three sub-systems agree, and the arbiter CPU generates a "compass error" to notify you that there wasn't a complete consensus. It still acts on the good data from the two sub-systems and the flight continues without issue. Milliseconds later, the compass resumes returning reliable data and the system continues operating flawlessly. There wasn't a catastrophic failure, you haven't flown into the Twilight Zone, the government hasn't hit you with a secret wave weapon... it was just a data aberration. Don't go looking for sinister explanations to the unknown. The simplest explanation is usually the correct explanation.
Once again, there is no evidence of GPS or other system failure, in fact the data supports that the systems were functioning correctly. I'm not sure where you get the idea that GPS positions are calculated or estimated from inputs from the controls either. It is just a record of the raw positional data received from the GPS device. If it fails or is obstructed, the data will be blank or it will repeat the previous value. If it is really screwed up it might return zeros or nonsensical values, thousands of miles away and obviously wrong, not merely inches from the last reading, 100ms ago. |
