Blackwood
fansa84fe8a4 Posted at 2017-10-17 12:21
I've found if I hit the shutter too soon, the image may still be processing in the camera and won't write the following shutter release unless I count to eight. It happens more with slower exposures a lot where the wheel around the shutter button keeps spinning for several seconds when compared to the higher speeds for stills where it may spin once. It's an odd camera at times, and especially with the manual Laowa 7.5mm lens in still mode where screen image looks okay, but actual image is blown out (Grossly over-exposed.), video side isn't as problematic.
I can see that happening, hitting the button too soon, when I went back up and took 2 shots to replace the one that was missing from the first flight. However, the set that was missing from the first flight had at least 2 minutes since the previous shot was taken. |
