hallmark007
Flight distance : 9827923 ft
fans3841f7df Posted at 2018-1-25 11:23
There's some situations that I've lost a bit in repeating patterns when flying home. I could use map to point the direction, but it''s easier to use RTH, specially when you running out of battery.
To fix annoying beep that is distracting people around you in the city area, it would be nice to have fe. 3 volume levels to select for the beep. Also when RTH is activated there could be a different flash pattern in the RC. Discreet would be OK sometimes, but activating RTH is not.
You must look at it as a safety feature not for the pilot but for those who are around the landing area of the incoming drone, so if they can hear it, it’s doing its job , what’s basically happening is a drone is coming in to land no longer under the control of the pilot. This is what it is for, if you had the option to turn it off or turn down the volume then most drone users would use this option and defeat the whole purpose of having it there in the first place.
In your manual it clearly tells you only use RTH in emergency situations, so if you are choosing to use it when it suits you, then you will be well aware that you have no choice but to put up with the beeping. |
