spiest78
Flight distance : 57034 ft
For what it's worth, it IS working if I set the Mavic Pro to WiFi mode (switch on the aircraft)
I have an iPhone 8 Plus, running iOS 11.1 with all software updated, incl DJI Go App 4. I cannot connect to the aircraft, said Mavic Pro, using either the mini cable on the RC nor via a standard Apple USB to Lightning cable via the bottom USB port on the remote. No matter what I do, it won't connect.
DJI Customer Service informed me that the iPhone 8 Plus is not supported, which is a standard answer... I tried my iPhone 5S, also on iOS 11.1 and it also won't connect.
Their helpdesk quality is very poor.. only standard answers at the level of "did you plug in the power cable"
HOWEVER, when I switch to WiFi mode, I am able to connect on my iPhone 8 Plus and everything is normal. Of course, I don't want to fly in WiFi mode, but just saying: it works.
Which leads me to believe it is an iOS 11(.1) cable/driver issue. Because: It worked fine on iOS 10.x. Now it doesn't, on two different phones on iOS 11. It doesn't work on either cable, Apple official USB to Lightning cable nor the mini usb cable to lightning on the remote. And WiFi connection does work. That does not leave many options open :-)
