IronM
Flight distance : 11227 ft
Romania
Hi.
I'm using a Google Pixel 2 XL with a Mavic Air.
I experienced casual disconnects when the drone was night in sight anymore and found out that fiddling with the small cable got it reconnected. It did this several times until I got enough and used the provided USB to USB C charging cable and connected the phone on the bottom USB port. Since then I've flown 4 batteries in a row without loosing signal.
(it may or may not have to do with developer mode on/off - sometimes I found it on other time off so cannot find a pattern there)
So, WHEN THE APP works, there is no issue with Pixel 2 XL phone, imho.
BUT my problem is not this: After 1-2 days of not using the DJI Go4 app, when trying to open the app it force closes showing that the app is stopped. (not even starting the app). I tried everything and it did not work (clear cache, clear storage, restart phone...). The only thing that works is: uninstall and reinstall the app.
I then found an .APK of the app thinking I can reinstall on the go...but after reinstall the app requires another 80MB of data to be downloaded and then asks you to login to their servers.
BUT this has again more drawbacks: if I use it in an area without GSN signal or internet I can only install it but cannot start the app. So useless again...
Has anyone encounter this also?
Now I don't know what to do...buy Litchi or a Nexus 7 II tablet?!? Either way....more money for something I already paid for! |
