S-e-ven
Flight distance : 5922034 ft
Thailand
lannes Posted at 2017-10-29 00:02
I don't think 2.4ghz is too bad if you can get this sort of signal range. The spark will not go as far due to battery limitations but this is proof the signal from the Cyclone can.
https://www.youtube.com/watch?v=LG2jjOfBF3s
I flew up to 2.5 km on 5.8 GHz in FCC Mode, with original RC antennas
Where the power is higher on 5.8 as it is in 2.4
I do not think, 2.4 with this mod is bad, I just would prefer to have BOTH options, like with the "normal" antenna upgrade.
It may be, that you will have great results in 2.4, but in some areas, I expect even the same or better results in 5.8, then. Less interferences, 5.8, the upper Channels, are not that often to spot as wifi networks.
Don'y you think? |
