Montfrooij
Flight distance : 2560453 ft
Nice job Ryan, lovely subject.
I would suggest some things for the next one: (only my opinion of course, if you like it this way it is ok of course)
- Set the sensitivity of the controls and gimbals to a lower level
- Don't record while moving the gimbal / drone small bits, only when you make a planned move from point a to point b (slowly). There are many little moves that make a less smooth viewing experience.
- Don't speed things, only when you want to get a specific effect (one of your shots was sped up a bit, I think because you wanted it to be shorter, better to cut it shorter than speed it up)
- Your footage is a bit over exposed, set the EV compensation to -0.7 to get a better average look. Manual is even better, but I can imagine you want to keep an eye on your flying and not worry about exposure.
- The footage shows some strange effect when moving. Like fast-slow-fast-slow (I can't find the word for this) for example in the shot that starts at 1:03. It looks like there is something causing this effect, not sure what it is. Do you see that also? And is it in the original footage?
Hope to see more from you! |
