crash1sttime
Flight distance : 1047503 ft
No home position is recorded when the quad first powers up, it flashes rapid green lights when it has locked its position on the earth.
GPS is only used to keep the quad in a position when hovering and switching it on then off does not move the home point.
As said if when you want to set a new home point flick the S2 switch up and down 5 times and watch the quad flash it's rapid green lights to confirm the instruction to set a new home point
If you don't have enough sats to lock a home point then just wait until you have and then flick the S2 switch as above, if this means hovering 60ft above you that is fine, oh and don't think that the home point will be set 60ft in the air, it doesn't.
