RobAlbania
Albania
ro-copter.de Posted at 2018-2-5 07:32
Hi Blackwood,
as Dji has not released a maintenance manual yet, i have no values, but this is how i did it. I put the props on the back side in landing mode and aligned them 90 degrees to the boom that holds the motors. Then i measured the distance from the surface where the i2 stood on to the tips of the propellers (has to be a perfectly flat surface). On the arm that had no play it was 18,5cm on the inner tip and 20,2cm on the outer tip. I aligned the other side of the i2 which had play in the arm to the same value and fastened it. There may for shure be other methods to align the props... in the end i think it is important that the props on both sides have the same angle, otherwise the aircraft produces a thrust to the side which the flight controller corrects all the time which causes dancing.
@ro-copter.de@
Thanks very much for your information about aligning the props on the I2. This is extremely useful, and I think DJI should publish this information and the "correct" rotor tip heights for the I2 as well as a full maintenance manual. Should the rotors spin exactly parallel to the ground, or should there be an angle, and if so what is the correct angle? I suspect this is a factor in the "instability" that many I2 owners have been experiencing.
