djiuser_cdOg3E2kmjtX
I have found that I can create a new mission using the Go4 app but it only allows me to select a point on the map and the AGL value from the start point. However, if I disconnect from the aircraft (Mavic 2 Pro in my case) and then reconnect without closing the app, I can load that mission and edit all of the details of each point. Unfortunately, I can only do this one mission, one time. After that, no matter what mission I load, I can only add points to it. My solution: Disconnect from the aircraft again, reconnect, reload the mission or load a different mission and edit away. Once I save it though, I have to disconnect and reconnect again to edit one more mission, one more time. The good news is, so far this has worked every time and I have been able to tweak my missions. |
