djiuser_drtYOSex5ic3
WA5TEF Posted at 1-1 12:52
I finally got Litchi to run on iPad while the Goggles used DJI GO 4 but I have not found a way to actually "load" the Litchi software onto the Goggles. I wonder if that is the way to make it run there?
DJI GO 4 is pretty lame when it comes to waypoint missions, whereas Litchi is very good. I use both apps, but DJI GO4 crashes quite a bit on my Smart Controller. All-in-all, Litchi is a more stable program, but more importantly is the only way to run waypoint missions with and degree of sophistication. If DJI came up with that functionality, and if they could solve the crashing problem, then I’d use it, but until then...it’s Litchi most of the time.
I haven’t tried my DJI goggles with Litchi. I do know that goggles are a selectable option, however, just not sure that the DJI goggles are part of that. I would guess that they’d work but would have to be plugged into the HDMI port on the controller. If it’s a Mavic 2...not sure |
