BobBob
Peru
mic75 Posted at 2017-11-12 18:10
I didn’t get it wrong, there is no mention of it under RTH or Critical battery and there needs to be, also the controls are unresponsive except for orientation. You only know this because landing protection was mentioned and before that you knew nothing of it in the manual because it’s not under critical battery.
You’re the ones being rube and insulting, I treat people how they treat me so you get what you give.
Also he had read the manual so there Geebax was wrong just like all of you, you didn’t even know about this before because you’ve never experienced it, you only know what’s in the manual and as I said there’s nothing in RTH or Critical battery and there should be.
Hi mic75.
You are right. I have enough experience on this topic using Litchi, instead of Go4. Litchi depends on Go4 settings to this apply to both.
Using Litchi, SMART RTH WARNING is under speech settings. It is only a voice warning, that does not affect your flight characteristics at all. You can say it is a decorative function. It will never do a RTH as you correctly say. You can set it wether using Litchi or using GO (Aircraft Battery Settings/Low Battery Warning). What you set using GO will be reflected on Litchi.
On Litchi, you CAN NOT set the CRITICALLY LOW BATTERY WARNING, you must use GO. This setting is very important and really critical, mainly when your are flying Litchi Missions (fully autonomous). This setting is not a warning but an actual limit for the AC to make autonomous decisions. When this signal is triggered, the AC will land wherever it is. So you must be careful of being in the right place at that moment.
One confusion here very common (maybe not yours) is what happen when during a mission, the AC CALCULATES (it is the aircraft who makes the calculation, not GO, GO could be disconnected) at any portion of the flight that it will not be able to complete the rest of the mission. On this situation, the AC will enter into the RTH procedure if and only if THE SMART RTH setting WAS ENABLED before departure. If you do not enable it, the AC will continue its mission till the point where it gets the CRITICAL low battery level and will land at that point.
If Smart Return To Home (RTH) is enabled before any mission, you can be assured (to the extent of Murphy's Law) that your drone will not be lost.
As important as enabling RTH function, is setting the RTH altitude. Please pay careful attention to this setting, because when the drone kick in the RTH procedure, it will go first to this altitude and then will get a unique heading, pointing to HOME position and flying to there horizontally. If you set it to 500 m and do not need it, you will spend battery unnecessarily and will activate RTH more promptly.
Nevertheless, there exist situations on which you could want to have Smart RTH disabled, as when flying over the water around a boat or even when you desire to land in the middle of a mission, before returning to the initial waypoint. To get this you should have to have many fake waypoints over the landing waypoint, that force the drone to go up and down over the desired landing point, till its battery gets depleted (i.e. it gets the CRITICALLY LOW BATTERY WARNING LEVEL).
My personal recommendation is that you assume that your drone will be out of control and that it will take autonomous decisions, so carefully do your planning and setting of the flying parameters.
To be sure of all that I have exposed here, you must transcend page 13 of the manual, by far.
I hope this exposition will can help others to be more confident to the RTH function.
Regards.
P.S.: One misterious issue is why DJI do not include all of these details on their manuals. My guess is one out of two: It is an accelerated world or they want you to ask them in order to make use of statistics. |
