fans3a27f77e Posted at 2017-12-12 19:47
Thats odd, I can also confirm that my patch antennae on my cendence stopped working after the last update. it worked perfect before the last update, now it works like 100feet away before cutting out. I noticed that with the CAN power plug plugged in, is when the problem persits, as soon as I unplug its significantly better but not nearly as good as when I first got it before the update. It would cut through trees and all type of obstacles now its no better than the omni but just more directional.
Sir, we sincerely apologize for the trouble caused, if the signal with Patch Antenna is poorer than Antenna in the same time and at the same place, we suggest to send in for diagnosis, we are sorry for the inconvenience. |
