Kloo Gee
Flight distance : 16783757 ft
Keep in mind that GPS/GLONASS satellites are in orbit and are constantly moving, so the number of available satellites visible from your location can be potentially changing all of the time. I mention this to clarify that just because you had 18 satellites last month when you flew, doesn't mean you can expect that same number the next time. In fact, had you flown a couple hours later, the number of satellites available in that same location on that same day likely would have been different.
DJI's drones such as the Spark utilizes a combination of GPS and GLONASS satellites.
GPS = US based positioning system
GLONASS = Russian based positioning system
Here is a site you can use to predict the number of satellites available based on your position for a given day:
http://satpredictor2.deere.com/lookup
Note that one of the variables they use in their predictions is an elevation mask. This is the angle from the horizon for satellites in which GPS devices essentially can't use. Note that your location will be affected by objects on your horizon such as mountains, buildings, trees, etc.
Also, I think many of us would be interested to learn from your experience. Would it be possible to upload your Flight Record to the following site and then post the resulting URL here?
http://www.phantomhelp.com/LogViewer/Upload/ |
