JJBspark
Flight distance : 12477300 ft
hallmark007 Posted at 2017-11-19 07:17
This is more a problem with airdata downloaded files than a problem with the aircraft , you will notice if you have any experience reading airdata logs that they use a colour coding system and problems are marked in red and purple, I think it’s already been pointed out to OP that he will get a much truer reflection of his log from phantomhelp.
If you know of a different way of reading airdata logs maybe you might enlighten us .
i know how analyse data files in general, did choose the wrong word for the WIFI, must be connecting and not switching. I will compare some other files where the user is switching mode, see if the wifi is re-connection as well. My guess now is not.
BTW, does anyone knows if the "phantomhelp" uses the same information as the "flight log internet app"?
Can always give a try to make a program myself, first thing is to get rid off the minus and plus yaw values.
I am used to read the full 360 compass headings! Yaw minus 30 is 330 degrees.
Cheers Hans
