djiuser_7zO4VsUoMAix
DJI Tony Posted at 2018-6-12 09:33
Sorry for the inconvenience that it may cause, have you tried to check if there's an update with the app? Please send a screenshot of the issue if possible. Thank you.
I just fixed this exact issue on my note 8, by doing the following:
Enable developer options:
Go to your Samsung Note 8 "Application" icon and Open Settings option.
Step 3: Under Settings option, select About phone, then choose Software Information.
Step 4: Scroll down the screen and tap Build number several times until you see a message that says "Developer mode has been enabled".
Enable Developer Option on Note 8
Step 5: Select on the Back button and you will see the Developer options menu under Settings, and select Developer options.
Step 6: Slide the "Developer Options" button to "On" and check "USB debugging".
Step 7: You will see a messages "Allow USB Debugging", click "OK".
Once that's done,inthe developer options, click usb configuration, and select PTP, picture transfer protocol.
That instantly fixed all issues for me. |
