Theo2
Flight distance : 104167 ft
As a Part 107 pilot, I need to perform and document regular maintenance procedures in my sUAV logbook. Every 20-hours, various items on the Mavic need to be checked and recorded; one of these items is to ensure that the screws have not worked themselves loose.
As I was checking the screws today, I noticed that the underside screw on the starboard side of the gimbal and the rear screw on the same side (behind the leg) had a clear substance applied to the inset of the screws. I assume this was done by DJI as some sort of tamper-evident measure. However, the insertion of the substance makes it impossible to ensure that those two screws are secure.
I removed the substance, checked the screws and then started to consider the implications of doing so. What if the Mavic needs to go in for repairs? Will DJI not find the substance and refuse me service? How can I observe Part 107 maintenance regulations without removing the substance?
Any thoughts are appreciated!
TIA
