PeteGould
As an Inspire owner I'm very conflicted about this. I absolutely see Tahoe's position. If an Inspire gets sucked into the engine of an A320 or 767 within a mile or so of an airport and causes a crash, I would expect INSTANTANEOUS legislation - passed and signed, very likely, within 48 hours - making UAS illegal throughout the entire USA. We would then go through years of litigation, legislation and rulemaking before, little by little, the market began to open up again. You can have all the disclaimer screens you want, making it the responsibility and the fault of the operator for disabling the feature. None of it would matter. A "drone" caused the crash of an airliner and people died. Case closed. DJI's market would be obliterated (and disclaimer screen or not, they would likely be sued into oblivion by the airline and the estate of every lost passenger).
You can't compare this to a car, because nothing anyone can conceivably do with a car could result in immediate federal legislation outlawing all cars. But I can ABSOLUTELY see that happening with UAS if one causes a mass casualty disaster.
On the other hand, if someone is certificated by the FAA, the tower is contacted, authorization is granted, and a NOTAM is issued (so the operation is perfectly legal and authorized), then and ONLY then, it should be possible to override the DJI-generated NFZ. The problem I suspect is that this would require additional and rather expensive development, and there aren't enough "pro" users who need to work within NFZ's with proper authorization to warrant the cost of said development. |
