DJI Susan Posted at 2017-11-25 01:34
Just to verify, is the firmware update successful? What's the current aircraft version? Is there any chance to verify this via the original SD cards?
If you use card reader the computer will ask you to sacn and fix errors because of some andriod files. I recommend do not choose. Most SD damages came from this way. Just click continue without scan.
both my sd cards are bad. they worked before latest firmware update. i had a 32gm sd card in my fire tablet i was not using so i tried it and it worked.
