Punchbuggy
Flight distance : 483166 ft
My guess is that DJI GO has detected that your No-fly database on the P4P requires updating. If you're getting a picture of a smartdevice plugged directly into your P4P, then that's what it wants to do. This is separate to a firmware update detected for installation.
You have a P4P Plus by the sounds of it. Not sure how that's handled using that (as the tablet is built in), but if you have a smartphone you can install DJI GO onto it then use that. Plug your standard cable into the phone, attach the DJI-provided adapter cable, then insert the micro USB into the P4P. But here's the important bit - when you get the update request in GO on the phone, insert the cable directly into the P4P with it already powered on. I don't believe it detects it properly if you power the P4P on After you've connected the phone. |
