Activation Status
3404 13 2017-11-30
mario64
Flight distance : 6450 ft
Hi all,
Got my Spark fired up and updated today. However, when it went through the activation process it repeatedly failed. Is there somewhere I go to check its activation status? I'd also like to verify my DJI Refresh status on it as well.
Thanks!
2017-11-30
DJI Thor
Flight distance : 13602 ft
Hi sir, could you please tell me if there is an error info when the activation failed. For this case, you can try to change another mobile device to activate, make sure the internet connection is enabled.
For the DJI Care Refresh status, you can click here for checking the remaining balance to confirm if they have bound successfully.
2017-11-30
mario64
I don't recall an error code. It no longer prompts me to activate. How do you restart the process? Keep in mind it is not possible to be connected to the Spark and to the Internet simultaneously
2017-12-1
mario64
Anyone know how to re-trigger Spark activation? Mine failed but it no longer prompts me so I have no clue if it is activated or not
2017-12-2
mario64 Posted at 2017-12-2 14:04
Hi, Mario, could you please PM me the serial number of the drone? I will help to check if the drone has been activated successfully, thanks.
2017-12-2
mario64
Thanks Mindy. Sent. Awaiting your reply
2017-12-3
DJI Thor
Mario, I am sorry for the late reply due to the day off. I have checked your serial number, it was activated on 12/1, 2017, since it was activated, you don't need to do it again. So, can you operate the drone normally and does it work properly? Let me know if there is a problem.
Besides, please kindly click the "Reply" button if you need to reply me so that I can get the reminder and can deal with it asap.
2017-12-3
mario64
Great thank you so much
2017-12-3
COCA
Flight distance : 35495 ft
Serbia
DJI Mindy Posted at 2017-12-2 18:35
Can you please check my spark activation status too ?
2018-4-30
COCA Posted at 2018-4-30 00:10
Sorry for the late response, yes, please PM me the serial number of your drone.
2018-5-4
adamvferguson
Flight distance : 40846 ft
Hello,
Sorry to post on an old thread, but I am having a similar issue with my spark.  At first the activation process kept restarting and when I was finally able to get to the end where I verify my account, it said the application failed. Now when I launch the app, it will not trigger the activation.  Also, when I enter the aircraft settings I get a message saying that parts of my aircraft may not be activated, but when I click the activation button, nothing happens.  Could you guys please lend a hand?
2018-7-19
DJI Natalia
adamvferguson Posted at 2018-7-19 10:37
Hello,
Hi there. I am very sorry for the inconvenience that this caused you. Can you please try to uninstall and reinstall DJI Go 4 app? Let's see if this will work. Please keep us posted. Thank you.
2018-7-19
adamvferguson
DJI Natalia Posted at 2018-7-19 11:58
Yes I have tried to re-install the app (twice now) and I am still having the same problem.  When I re-install the app it also does not re-initiate the activation process. Is there another way I can activate my drone?  I'm using iOS.  Here is a screenshots.
2018-7-19
Prince Studio
Pakistan
ohaefiepa20293
2018-9-28
