hallmark007
Flight distance : 9827923 ft
I think looking at the area you were flying in it’s almost certain you picked up some magnetic interference on the ground, this can happen regularly from taking off from concrete or close to metal objects, you may not see this straight away , but it can take effect during your flight, and it looks like this happened here.
Before you take off you should always check the small red triangle in lower left hand corner it should be on the same heading as your Spark if it’s not you need to move location and start again.
Check out link below might help with your preflight.
https://forum.dji.com/forum.php? ... &fromuid=260008
