Arcicorsa
Flight distance : 235892 ft
Czechia
uncino78 Posted at 2017-12-7 04:07
thanks arcicorsa but with 5.8 the wifi works well, but disappears when I try to switch to 2.4 as the video you mentioned and I would like to be able to use both frequencies according to the case without cable otg
I will add that the frequency you see in Dji GO4 is the frequency at which communicates the controller - Spark, not controller - phone. Simply put, if you set 2.4Ghz in Dji GO4, the driver communicates with quad to 2.4Ghz and controller - android to 5.8Ghz, if you set in Dji GO4 frequency to 5.8Ghz so quad - driver communicates to 5.8Ghz and controller - android on 2.4 Ghz. |
