Kloo Gee
Flight distance : 16783757 ft
hallmark007 Posted at 2017-12-18 09:52
Hi Suren, looking at your logs as Kloo gee said when your aircraft went into RTH wind was your problem. Although Kloo mentions 22mph the reality is you were within 100 metres of home so Aircraft speed is curtailed to 14mph and if wind for the day was 16mph then it is to strong to make any headway. Your Aircraft did go into auto landing and even then was loosing some ground from there it went into Forced Landing at .3 of a metre as it should do and the landed.
There is nothing peculiar about your flight , you could have canceled RTH and tried to fly back in sport mode .
You said you used a fresh battery but your log shows battery at 75%, the reason for negative altitude reading is due to homepoint being above the area you landed in.
Ah, yes, thanks for the correction on the speed. |
