mdlowe
Hi everyone, i have a Phantom 1, i'm new to Quadcopters and have made some mistakes and am learning however if anyone can help with a couple of things....
Firstly i have updated the system to 4.02 which did improve things...
I have also carried out an advanced IMU calibration.
It doesnt hover on a dime as others have said, it does wander a little, however when hovering at eye levell it appears to be level, but the camera says something different at altitude,(about 200 ft).
First question, when hovering i try to rotate by yaw but the Phantom pitches up and starts to roll but i've noticed from video footage that it isnt hovering level, its over at about 5 deg any help with this would be appreciated.
Second question, i have a set of carbon props, they were balanced, before i did the system update i managed to crash in a muppet way and damaged the propellors, i have cleaned up the 2 damaged propellors (1 x CW and 1 x CCW prop)and rebalanced them, but in sorting the damage these 2 propellors are now 3 mm shorter than the other 2, is this going to cause inherent handling problems due to differential lift now they are shorter... should i bin them, and get a new set...
I couldnt use the prop guards as with the carbon blades the handling was attrotious.....schoolboy flying error....!!!
Any advice would be appreciated..should i re do the calibrations again....?
Mikey
