lannes
Flight distance : 4465 ft
Indoors, always start from the floor, auto take-off should raise it to 4ft.
Remember stability won't be as good as you won't have gps, also make it as bright as possible with all the lights on etc. so the VPS works better.
It may not hover well if the floor doesn't have a pattern on it, so you'll have to be more watch full on the controls. Watch out for any compass interference and quickly land if your starting to get these
VISION SYSTEMVelocity Range | ≤22.4 mph (36 kph) at 6.6 ft (2 m) above ground | Altitude Range | 0-26 ft (0 - 8 m) | Operating Range | 0-98 ft (0 - 30 m) | Operating Environment | Detects clearly patterned surfaces with adequate lighting (lux>15) and diffuse reflectivity (>20%) |
Turn on obstacle avoidance and put on propeller guards
Watch out for the critical battery return to home it may RTH at 100ft which means it will hit the roof if it disconnects for some reason, indoors I have the RC disconnect set to hover.
Choose 5.8ghz frequency, due to a lot of interference on the 2.4ghz mode, it may already default to this if your using OTG
