Plank!
Flight distance : 526798 ft
Wachtberger Posted at 2017-12-18 06:00
It's a bit hidden. Go to the CS "Settings" menu, then "Launcher settings". There you can select which ones you want to see in the Main Menu. E.g. you can replace the DJI GO (better leave GO 4 where it is) with DJI Pilot.
I use GO and GO4 equally - as I fly an Inspire 1 as well as the Mavic Pro, so whatever app I remove, it's going to have to be swapped back on again.
Will give the Pilot app a chance with each bird, if it connects to them, if it's any use I may (in time) ditch one of the GO apps... |
