TexasAerials
Flight distance : 566952 ft
DJI says that spark is rated to fly in temps down to 0C, so technically it should not be flown in freezing temps, but the main concern is the battery temp. Li-Po batteries lose a lot of their efficiency when cold, and the amount of power out of them is reduced. This can cause the battery to drop faster than expected, and get you into a sticky situation if you fly out a long distance. |
