Farnk666
Flight distance : 1711394 ft
I've had similar experiences in the update process.
The AC updates fine from the micro sd card, but remotes required a number of attempts using a variety of (freshly formatted, bin file copied over each attempt) USB sticks. All USB sticks used were and are 100% working on the PC.
Previous upgrade, my master Tx would not initiate upgrade from any USB stick, but the supplied micro sd in a usb reader got the job done. The same reader / micro sd combo did not work on the slave tx, but one of the 'failed' USB sticks did.
This time around, the AC updated via micro sd, but both Tx would only upgrade from different USB sticks that hadn't worked last time around.
Each time the Tx upgrades start, you can see that the USB is being accessed, but the process doesn't initiate successfully. So no common thread apart from 'try lots of different USB / Microsd card and reader options until it works'! |
