hallmark007
Flight distance : 9827923 ft
Looking at your log it shows only you as controller pushing throttle forward to increase altitude, it never raised by itself.
When it went into Forced Landing this was caused by you pulling back throttle, yes this shouldn’t have happened but if you look at your altitude which was 46.6 ft but VPS was reading .3 metre so it thought is was nearly on the ground , this must have been caused by dirty sensors or they were completely misted , it didn’t land first time most likely because it didn’t trust the ground underneath, however again second time you can see you pulling down on the throttle and this time is when it fell.
Who’s fault was it, it’s hard to say what dji will do about it, we have seen a number of other cases here with people flying in clouds and all of a sudden aircraft falls out of the sky , and these were refused warranty.
Mist is same as rain worse in the fact that it can mist up your sensors and that looks what happened.
Hopefully not to much damage done. |
