Gixr.thou
Flight distance : 13025 ft
G'day All,
I have been tasked with filming the construction of a new school. The process is going to take over 12 months from beginning to end. What I would like to do is film a path over the area, then go back a few months later and fly the same path with the same camera angle, and repeat again and again until done. Then when I edit the film together, flash back and forth through the construction before and afters before doing a final fly through and internal montage at the end.
So basically, can Spark do it? Is it possible to map a path or record a path and have Spark re-fly the exact path again and again? Do I need alternate software? Or is it just not possible?
Advice and suggestions on how I might be able to do this would be greatly appreciated.
Of course if you can wait 18 months I'll share the end result. :-)
Cheers All
