S-e-ven
Flight distance : 5922034 ft
Thailand
fanse5dc1f7f Posted at 8-17 12:03
I think that the picture you have posted is with the .org cable installed, The latest software go4 will not recognize the org cable so we get the same screen as any Wifi hookup with no option in mc settings to turn flight modes on or off as has been stated earlier in this forum, thank you for your suggestion but that is not an option as that switch does not exist in version 4.3.20
Your problem is, right now, that you can't even see the switch, b/c the newest Go4 is not recognizing the otg, right?
Sound like iOS, but however, try this:
In case you are on iOS (sorry, saw to late that you are ;-):
GET AN ANDROID phone/device
Just for checking on the switch and switching it "on" (green)
In case you are on android, go to apkmirror, get an OLD (4.1.15, I'd suggest)
Keep the line of connecting the RC with OTG to your phone/tab, meaning:
Plug in into your phone, switch on the RC, if LED is steady, plug into RC
(RC has to charge the phone, but you probably know about this ;-)
Now check on the setting in above picture.
If the intelli flight modes aren't enabled, enable them, case solved for now!
The setting will stay usually "for ever"
Untill another update of firmware/Go4, perhaps. ;-)
I think I can remember that this happened a year, or almost 2 years ago, too.
After update no sport.
So give it a try, it might get you back in Sport
Oh: In case you are on Droids, all the time:
Instead of changing the actual Go4 to an OLD one, get yourself the Go4 mod 2.0
You can install this one aside the newest ones.
And have the OTG switch "ON/Off" options, plus some mavic flight modes.
Include, as I learned a couple of days ago, the cinematic mode, with "sport" speeds, but no tilting the cam in curves. Win/Win ;-)
Good luck |
