Indoor realestate video with the Spark, thoughts on this video?
12
7290 50 2017-12-23
A CW
Flight distance : 13838848 ft
No worries and guess this was for work anyway so had to be done
2018-1-22
Mariuss
Flight distance : 2480515 ft
Norway
Grmachine Posted at 2018-1-22 12:24
I like it, all my flying has been inside so far (crap weather)  my Spark is well behaved inside. But I’ve read some stories. Flying out the window and away from the building is a neat image.
Thank you Grmachine!
I did encounter quite some action doing that, the GPS kicked in which turned off the tripod mode->speed... Just be aware of it in case you would try the same
2018-1-22
Mariuss
Norway
A CW Posted at 2018-1-22 13:40
You're correct Note to self: match indoor/outdoor lightning as far as possible..
2018-1-22
A CW
Mariuss Posted at 2018-1-22 13:50
And keep the prop guards on and make sure your downward vision positioning system is working perfectly with sufficient light and stay away from magnetic interference and keep it in tripod mode LOL
2018-1-22
Mariuss
Norway
A CW Posted at 2018-1-22 13:53
Propguards: on, the rest: not so much haha. Do you experience tha app crashing ALOT?
2018-1-22
A CW
Mariuss Posted at 2018-1-22 14:41
I did on IOS 11.1 (use an iPhone 7+) but never since the upgrade to 11.2 (now 11.2.2)
2018-1-22
Peter Burn
You did a fine job with that Drone.  My wife does Real Estate videos and the Glidecam/vest are getting to be too much for her.  You video inspired me to add a Spark to our fleet.  Ordered one just now.  Is it possible to reduce the joystick sensitivity, same as P3 and P4?
2018-3-22
Mariuss
Norway
Peter Burn Posted at 2018-3-22 20:14
Hi Peter!
Happy to hear the video hopefully will  help you out at work!
Some points to remember:
There arent any atti/s/p switch on the spark, one challenge with that is if you are flying indoors (atti) and head for the balcony outside, the gps positioning will kick in and then the speed and response will change.
example: Some of the slower maneuvers indoor in this vid was done in "Tripod Mode" which will reduce the sensitivity as you ask of. One problem with this mode when flying from indoors to outdoors is that it'll be deactivated as a result of flying in atti(indoors) and then to gps(outdoors). To avoid this i taped a piece of tinfoil to the back-top of the drone to cover the gps tx/rx module which solved this problem.
Use propguards
edit: there is a "sport"-mode button, not that it'll be used for this purpose.
2018-3-25
djiuser_1bSeswJTGqQ8
Flight distance : 36860 ft
So Mariuss, what software did you use to edit, upload video?  And I must say, it is an awesome video!
2019-7-15
Mariuss
Norway
djiuser_1bSeswJTGqQ8 Posted at 2019-7-15 02:09
Hi! This was edited using PP and uploaded to YT. Thanks!
2020-3-25
360propertytour
India
Welcome to the 360 property visits, we are one of the main virtual sweep and 3D photography specialist organization across UK and outside also. 360 virtual visit is ongoing innovation and most ideal approach to feature your properties inside and outside . There are endless organizations, those are utilizing 360-degree virtual visit innovation to offer the best intelligent experience to their site guests, so they will be more natural about the item or administration what the give.
Visit: 360 virtual tour
2020-10-13
12
