Mariuss
Flight distance : 2480515 ft
Norway
Peter Burn Posted at 2018-3-22 20:14
You did a fine job with that Drone. My wife does Real Estate videos and the Glidecam/vest are getting to be too much for her. You video inspired me to add a Spark to our fleet. Ordered one just now. Is it possible to reduce the joystick sensitivity, same as P3 and P4?
Hi Peter!
Happy to hear the video hopefully will help you out at work!
Some points to remember:
There arent any atti/s/p switch on the spark, one challenge with that is if you are flying indoors (atti) and head for the balcony outside, the gps positioning will kick in and then the speed and response will change.
example: Some of the slower maneuvers indoor in this vid was done in "Tripod Mode" which will reduce the sensitivity as you ask of. One problem with this mode when flying from indoors to outdoors is that it'll be deactivated as a result of flying in atti(indoors) and then to gps(outdoors). To avoid this i taped a piece of tinfoil to the back-top of the drone to cover the gps tx/rx module which solved this problem.
Use propguards
edit: there is a "sport"-mode button, not that it'll be used for this purpose.
