DJI Thor
Flight distance : 13602 ft
Just to verify, do you mean that the motors won't start? If yes, like the reply on 2#, please check if you had mounted the propellers. If you just want to test if the motor will spin and don't mount the props, you can push up the throttle and the motors will keep spinning.
If you want to fly the drone, you can also use the auto takeoff in the app, slightly push up the throttle stick and the drone will fly. If you are very familiar with the operations, I suggest that you read the manual or try to launch the simulator to practice first. Keep it safe and fly with caution.
If this is not your case, it would be nice if you can provide me with an operating video for a better confirmation. Thank you.
